DistributedBen
- Mar 26, 2004
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing?
Processing photos with Photoshop (CS3, for now. CS4 or maybe Lightroom down the road). I plan to upgrade my camera early next year, so Ill need something that will be able to handle working with files from 20MP cameras and resulting multi-layered PSDs without issue. I dont think my P4 2.4GHz and 2GB of RAM are up to the task.
I play the occasional game (FPS), but I dont need the latest and greatest on this front. Ive always gone with the best card I could find under $200. In the past Ive had better luck with NVidia, but I havent bought a new card in about 5 years.
Something quiet would be nice too.
Id like to stay around $1,000, including tax.
3) Where do you live?
Texas
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything except KB, mouse and monitor.
None
6) Will you be overclocking?
No
Have a Dell 20 Ultrasharp I plan to keep for the foreseeable future. Would like a card with 2x DVI in case I want to add a monitor down the road.
Next 30 days
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
None of the above.
10) Do you already have a legit and reusable/transferable OS key/license?
No, I will get a copy of Windows 7 Business with the parts.
It has been a long time since Ive built my own system, so Im trying to get back up to speed on the current hardware out there. I was initially looking at going with an i7 920 system since I could get triple channel RAM, allowing for 12GB of RAM relatively cheap. I figured I could dedicate a few GBs to a RAM disk for Photoshop scratch. But it looks like an I7 920 system would cost me about $1,500 which is more than Id like to spend, especially if the performance difference is marginal over something like an I7 860 / I7 750 system with 8GB of RAM.
Thanks in advance
Texas
None
No
Next 30 days
None of the above.
Thanks in advance
