Basically I'm writing a C program to read in a list of numbers from a file and output their binary mirrors and number of bit 1's in their binary representation. The file has a 32 bit unsigned decimal number on each line and the number of lines has not been specified. So I wrote the following code:
And the program is doing what it should except that it reads the last line twice. The output to a sample looks like:
Code:
#include <stdio.h>
#include "bits.h"
int main(int argc, char *argv[])
unsigned int num;
if(argc != 2){
printf("Invalid Arguement(s)\n");
return 0;
FILE *fp;
fp = fopen(argv[1], "r");
printf("Binary Mirror: Number of bit-1's\n");
while(!feof(fp)){
fscanf(fp, "%u", &num);
printf("%u %u\n", bin_mirror(num), pop_count(num));
fclose(fp);
return 0;
Where the last line is repeated. There should be only 10 lines (11 if including header) printed out. I cant figure out where the bug is. The while loop should be broken when the end of the file is reached but for some reason the last line is read twice. Any ideas?Binary Mirror: Number of bit-1's
510274632 13
2147483648 1
1744830464 3
2994733056 5
981991424 6
3231383552 7
1412714496 8
2411032064 15
476721824 12
4287846876 21
4287846876 21
