I came across a nasty bug, and I wanted to share this with all of you, in case you ran into it.
This involved a system using an Asus P5E motherboard (running the latest BIOS - 0601), PNY nVidia 8600 GT, and NEC LCD2690WUXi (connected to the DVI-I port on the monitor, and the DVI port on the card).
Saving you the story of its occurrence, and the pain of tracking down the cause - I present you with the final end result:
If the NEC monitor is plugged into the video card AND turned on BEFORE power is applied to the motherboard (and I don't mean turning the system on - I mean supplying power to the MB, either by plugging in a live power cord to the PS if you don't have a hard switch on the PS, or simply turning the switch on if you do), then as soon as you try to turn the system on, the BIOS gets corrupted, and the machine will no longer be able to boot. It will power up for a fraction of a second, and then power down. A few seconds later, it will power up again for a fraction of a second, and then power down again. This will continue until you pull the power.
The corruption in the BIOS can be repaired by clearing the CMOS, but the only way to keep the problem from occurring again is to make sure that the MB sees power BEFORE you turn the monitor on (or before the video card sees a live cable). Mind you, once the PS is plugged in and the hard switch (if you have one) enabled, the order no longer matters between when you turn on the monitor vs when you press the power button to boot your system, because at that point, the MB is always seeing power. Once you pull the plug (or do something equivalent), then this becomes an issue again.
So, the first question is - is one of these components a dud, or is it a general bug in the hardware/software of one of these items?
And the second question is - which component is responsible?
The primary reason for my post is to warn people of this, so that if they should see these symptoms, they might have a heads up as to what's causing the problem and how to resolve it.
The secondary reason for this post is to see if there are any people with a hankering to be guinea pigs and see if they can reproduce this issue. For all I know, this issue occurs regardless of MB, or monitor, or video card. Or perhaps it's only Asus MBs, or only the LCD2690's, etc... I don't know - I don't have the equipment to run a full barrage of tests to isolate the issue.
However, as a precautionary note - on the system I encountered this on, clearing the BIOS and making sure not to repeat the offending action resolved the issue fully. But I can't speak for other systems, so I take no responsibility if something more catastrophic occurs. >)
