Budget system
Hey, first post here(so please be gentle).
A little background on myself
-I've been lurking around reading these forums for a little while now. I'd consider myself a noobie builder at best. I built a system for myself about 1.5 - 2 years ago, so most of the research I did then is mostly out of date now. I went with a huge steel case (for more room, protection, and airflow) and a big crt monitor. After hauling this rig back and forth to school a few times I wished I had went with something lighter :D
Anyway, one of my friends needs a new system and asked me to help him build it for cheap. Everytime I sit down to price out a budget system for him, I always find myself upgrading to best bang for your buck items. I've got a few thoughts for the build, but I figured I would ask you guys for advise to see if you could give me some better ideas.
Right now I think Quality/Reliability/Stability > Low Cost > Quietness > Looks. I'll probably be his tech support, but I don't want to be on call 24/7(i'm not that good at it anyway) so stability and reliability is high priority.
I was thinking that the Qpak looks like it would be good for a first time SFF build, but I was also considering the Antec NSK2400 because it comes with a 380w PS(the PS that comes with the Qpak seems like crap from reading previous posts). The antec is $85 and I don't think I could get a Qpak + a reliable PS for under that. On a side note, A flat screen monitor should be fine sitting on top of this case right...probably a dumb question.
The motherboard I was looking at is the ASUS A8N - VM 939 - $81. It's got decent onboard video, which could cut costs and seems reliable. I don't think he'll be doing that much gaming, so it should get him by.
Processor Athlon 64 3200+ Venice 2000Mhz - $155. Seems to be a reasonably priced, decently fast chip. I went with intel on my first build(thought it was more stable/better temps), but after realized I should have done more research on the AMD side. The retail Heatsink seems to be the best option for the Qpak and I think it will work in the Antec as well.
This build with the Antec case and rest of the stuff I would put in comes to about $900 w/ shipping. I'm not sure if it would be better for him to go with a cheap Dell. I did a quick comparison and he could get a similar set up for about $600 probably (bigger case though). After useing my cousin's new $399 Dell I don't think this would be the best option ( seemed slower than it should have been to me). Also considering starting with a barebones, though I don't know if this would be a better/cheaper option. :confused:
If you were ablet to get through my long winded post, any advice you can give on quality/best bang for the buck items would be greatly appriciated.
The differences in CPU speeds has been fairly minuscle compared with the improvement that more RAM can lend. If you can save money by going down on processor and use the money to buy more RAM, do it.
I like many of the Shuttle SFF setups.
Systems from a year or three ago are still pretty nice, especially if you use Linux on them.
