Budget SFF Build critique
That PSU is probably about an inch wider (deeper?) than some alternatives, might not be a problem, I don't know how cramped that case is.
It was always was $150 Kil4Thril... it just just how newegg cart works, their are 2 free games bundle with that 4870.
XFX 4870 $90
Stormrise $30
Battleforge $30
Total $150
Shit. I picked it because its modular (thought that'd help with the cramped space) and cheap.
It should fit no problem, I've seen v351 builds with psu's that are 140mm deep and it looks like they have a few cm to spare. The OCZ psu is 160mm.
Oh my, so my OCZ is actually a much larger PSU than is normally run on these? I guess I should browse that PCV topic and see what people are getting. I want to have as much room as possible for airflow and convenience sake. Do you have any suggestions?
XFX 4870 $90
Stormrise $30
Battleforge $30
Total $150
For $50 extra I would definitely ditch the 4850 and get the 4870 1GB. More VRAM, GDDR5, higher performance, and 2 games for only $50 extra is a great deal.
XFX 4870 $90
Stormrise $30
Battleforge $30
Total $150
I see how they did it now. Thanks. Now I must talk myself out of buying 2 of them......wife's out of town, so I won't die until either Visa or Fed Ex shows up. :p
Compare your build to this one, and see how you're doing:
http://cgi.ebay.com/Zotac-GF9300-D-..._PCs?hash=item19b53577cf&_trksid=p3286.c0.m14
$449
The kit includes:
1 x Zotac GeForce 9300-ITX WiFi Mini-ITX Motherboard
1 x Intel Core 2 Duo E7500 2.93GHz Processor (Retail Box)
1 x Low Profile Socket 775 CPU Cooler
1 x 2GB 800MHz DDR2 Memory
1 x M350 Universal Mini-ITX Enclosure with additional HDD/FAN Bracket
1 x 40x40x10mm Case Fan for M350
1 x PicoPSU-150-XT with 102W 12V AC/DC Adapter
1 x All product manuals and documentation and driver CDROM
I wouldn't say it's much larger, I was just using the other psu as a comparison. 160mm psu will fit fine, going with something smaller isn't going to have any affect on airflow, it's at the top of the case.
Could I get clarification on the issue of if I need a CPU cooler and what modular PSU would be a better buy?
I can't comment on the PSU as mine hasn't arrived yet, however I would check out the 20+ page thread on the V350 for ideas. The cooler would definitely be worth the cash.
