Budget SFF Advice
xrc
Hope everyone is doing ok and staying safe during these times. Wanted to get some advice on the "best" SFF build that can be bought around the $100 range. Options that I am reading up on:
- HP Elitedesk G2 with sixth generation i5
- Cheap NUC with 15watt i5
- Lenovo M93
Just looking for something to run Linux and internet, thank you in advance!
$100 for the whole system will be very hard to build out with new parts. Will definitely be interested if you can pull it off. Good luck though!
Bought a used one on here for $80 shipped for my neighbor. It was a 3020 SFF with a i5-4590... So not 6th gen, but still reasonable (especially for her light work load). I tossed in a small SSD so it boots and loads everything quick.
Thanks fellas. I was able to score a Pro Desk 600 pretty cheap that is running Mint very well!
