If you are using zfs or any non windows OS, I would stay away from expanders if possible and use a SAS HBA instead because on any of these systems you most likely will not be using HW raid. Or do you not have any PCIe slots on your motherboard?
I got this in the end:
http://www.newegg.com/Product/Product.aspx?Item=N82E16816117157
Make sure you install the IT firmware.. link
