Budget rig for parents
blairellis
My parents have a single core 2.0ghz Dell w/512MB RAM right now that the 20 GB HD is filling up and is slowing way down. They need to replace the computer. Its about 4 years old. Here is my initial thinking on what I want to put together for them. They have speakers and input devices already so those aren't needed, I also have a OS to put on there so that won't be needed.
Case: http://www.newegg.com/Product/Product.asp?item=N82E16811190072
HD: http://www.newegg.com/Product/Product.asp?item=N82E16822136062
Mobo: http://www.newegg.com/Product/Product.asp?item=N82E16813128045
DDR2: http://www.newegg.com/Product/Product.asp?item=N82E16820231102
CPU: http://www.newegg.com/Product/Product.asp?item=N82E16819103036
PSU (Needed? Or can I get away with the one in the case?): http://www.newegg.com/Product/Product.asp?item=N82E16817189005
CPU Cooler: Have a stocker from my 3800 I can use right?
Optical Drives: Can I throw a CDRW and DVD drive from a Dell or are those proprietary? I am assuming its an IDE drive of some sorts, I haven't cracked open the case yet.
Total Shipped to 49301: $341.57
Odds are I'll be swapping memory and processors from my computer, AData 1gb (5x12) and x2 3800 for the memory and cpu listed here so I can over clock some more without being limited by the ram and windsor core. They wont ever know the difference either. My stuff is quite new, as of probably 2 months ago.
Thoughts, ideas, suggestions?
Looks like that PSU is pushing out ~25A on the 12v. Seems like a decent quality PSU. The Brisbane doesnt tax it nor does the lack of GPU. You should be fine with the one from the case.
Are you using vista as onboard graphics usually can't run Aero.
It will be XP Pro.
It will most likely be my Windsor. I've heard the Brisbane is easier to hit 3ghz with on air. So I'll be swapping my 3800 for the 3600 ;) The same still applies?
BTW, this will have NO overclocking. What is the smallest PSU any of you would go with without the graphics card and what IF I were to add say a 7300GT or something as small as that?
I'd say any reputable 300W+ would be favorable, but the one in the case should be fine. Also if your want to save a few bucks check out the [H]ot Deals forum.
that case psu doesn't look promising. I'd avoid.
Theres a Dell deal for $259 without OS.
Dell Business has this Dimension E521N Desktop with No Monitor for $259 + $30 shipping, with free shipping on $399 orders. It also does not come with Windows, so be prepared for that.
# Athlon 64 X2 Dual-Core 3600+, 512MB DDR2, 80GB SATA Hard Drive, 16x DVD-ROM
# GeForce 6150 LE Video, 7.1 Audio, 10/100 Ethernet, Dell Keyboard/Mouse
add in another stick of ram...
$18 - Corsair ValueSelect 512MB DDR2-667 VS512MB667D2
If you have a 3800+ right now, I'd suggest upgrading your CPU/Mobo/RAM and giving them yours. Get yourself an E4300, a DS3, and some DDR2-667 sticks.
Other than running low on hard disk space, is there a compelling reason why your parents need an all-new computer? It seems to me that a fresh reinstall, some additional RAM, and a 2nd hard drive would solve all the problems unless they're doing really heavy-duty video or image processing. I don't want to squash your enthusiasm (hey, I love building new rigs myself), but if you can solve your parents computer problems and save them several hundred bucks at the same time, I'm sure they'd be very appreciative.
Agreed. If you can upgrade the memory and hard drive for less than $200 and reinstall the OS, you could save them a ton. Alternatively, you could buy a Dell w/out OS and install yourself. Check Dealnews.com for prices on Dell's w/out OS.
slickdeals.net has a link to pretty decent budget system for only $219
Dell Home has the Dell Dimension C521 AMD Athlon 64 X2 Dual-Core 3600+ Desktop for $219 w/ free shipping. Remove the 19" LCD monitor (subtracts $230) to get the price. Thanks dempa.
Specs:
AMD Athlon™ 64 X2 Dual-Core 3600+
Genuine Windows Vista™ Home Basic
No Monitor
1GB Dual Channel DDR2 SDRAM at 667MHz- 2DIMMs
160GB Serial ATA Hard Drive (7200RPM) w/DataBurst Cache™
16x DVD+/-RW Drive
NVIDIA GeForce 6150 LE Integrated Graphics GPU
Integrated 7.1 Channel Audio
56K PCI Data Fax Modem
