budget network/cable tester?
mds2004
I usually use a Fluke from work but I want one for myself and do not want to pay the premium.
As for features, I would like for it to have the normal testing, cable length, & length of fault. It would also be nice if it can do ping testing and even reading the speed or capability of line/port. I of course know these are features of higher prices testers. Toning is not that big of a deal for me as I will probably end of with a fluke intellitone unless you know of another where I can change between high and low sensitivity.
These are ones I have been considering:
1) Test-Um NT700 ($277) or NT750 ($370) (link): Like I said I was already planning on purchasing a separate tone & probe, but the NT750 comes with seven extra remotes which have come in handy in the past for me. It also does not tell you how far down the line the fault is and it also only reads speed up to 100Mb/s.
2) Monoprice's version at $85! (link): I know it is a cheap one and I do not know how long it will last. It does read length and will even tell you where it the fault is on the line. It however will not detect a split in the line when in remote mode.
3) ByteBrothers RWC1000K @ $390 (link): I dont need it to certify, but I do like some of its features. It will read the speed of the line and the capability of it. I am not sure if it will tell me where in the line the fault may be. It also seems a little cheesy somehow. It does come with an analog tone probe.
Any ideas or suggestions?
Is it really worth it to purchase the Fluke Microscanner2 at ~$400 and then their probe at $120?
I have one of the earlier Test-Um, and it's ok. The additional remotes are nice, but really haven't used them all that much.
No idea on the Monoprice tester, but have had my eye on the ByteBrother's unit. Considering how the Test-Um unit is built, it would be odd to classify the BB unit as cheesy when you have a Test-Um unit in your hand. IMNSHO, I like the idea of being able to certify the wire, since that usually costs an extra amount from a wiring company; and you can at last guarantee that the media will perform.
