Budget gaming/HTPC build
Hey everyone, view these forums frequently but don't post since I usually find the information I'm looking for. Well I'm starting a new build for living room gaming since I sold all my consoles and am not sure what the best bang for the buck system is. I've been watching the combo deals at Microcenter and the new 7850k CPU but have read that with a discrete card there are better options. Currently I am gaming on my first build which is an old 775 E6600 with an 8800GTX and 4GB RAM. Just put in a HD 6870 though and it has suited me well. I could also just throw the 6870 into this build and reuse the 8800GTX if that is needed to stay in budget. Any feedback would be great :D
1. What will you be doing with this PC? Gaming, Photoshop (or other intensive programs), Web browsing, strictly HTPC/Playback, etc. (If you have multiple things you want to do with the system, make sure you rank them from most important to least important).
Gaming (Lately mostly Planetside 2, but would like to play upcoming games such as Titanfall) HTPC/Playback
2. Will you be overclocking? (If so, are you looking to watercool?)
Never tried but open to it if it will be necessary.
3. What's your budget? Are tax and shipping included in this budget? Is your budget flexible? Is cost a driving factor in component selection?
Trying to stay around $400, not including shipping, tax or anything. Could increase budget a little if needed.
4. Where do you live? Do you have any big B&M (brick and mortar) computer chains nearby (e.g. Microcenter, Fry's, etc)?
Close to the Denver Microcenter.
5. What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need (especially if you will need 3.5" hard drives or expansion cards as these may restrict case options).
CPU, Motherboard, GPU (if not going APU), Case, Power Supply, RAM.
6. If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. For reused parts, list brands, model #s, and, if applicable, firmware revisions.
I have several laptop HDD I figured I could use starting out rather than spending money on an SSD right now. Have a Dynex power supply but am afraid to use it because of the reputation.
7. What specific features do you need in a motherboard? RAID? Thunderbolt? Crossfire or SLI support? How many USB 3.0 and SATA 6Gb/s? etc. Which is more important, size of the system or having the particular feature? Make sure you indicate *required* vs. *wanted* for each feature you list.
No specific requirements, mostly want a mATX or ITX build though. Extra expansion if I want to add a TV tuner later would be nice but definitely not required.
8. What resolution output do you need? 4k playback, 1080p playback, etc for HTPC or give a vertical/horizontal resolution for gaming SFF rigs. Do you need multiple monitor output?
This PC will be connected to my TV and it is only 720p which should help with hardware requirements.
9. Does this system need to fit into a particular space and do you need an optical drive? Think entertainment center shelves, closet space, rackmount, etc. Many modern SFF cases have either removed the optical drive or have been constructed so that removing the ODD increases the configuration possibilities immensely.
Its going to sit in an entertainment set up with removable shelves so size is really no concern.
10. How comfortable are you with custom case design/modification and electrical wiring? What tools do you have (Screwdrivers/Leatherman, Drill, Dremel, Metal snips, Soldering Iron, Bending Brake, CNC/Welding machines/Plasma cutter, etc...)?
I don't have too much experience with this, but if it is required I'd be willing to attempt it.
11. How important is the noise/silence of this sytem? HTPCs typically want to be quiet while all-out SFF gaming rigs don't care
Not concerned about noise of the system.
12. How mobile does this system need to be? Need a carrying handle or carrying straps? Is weight important (carry-on bag, etc)? Water cooling quick disconnects, etc?
It would be nice if it was more mobile, but will most likely just sit in the entertainment center.
13. Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? Remember that OEM copies of Win7 have issues with new motherboards
Yes, have Windows 8 64 bit from a student account.
14. When do you plan on building/buying the PC? Immediately, in a couple weeks, 3-5 years?
Soon, most likely this week or next.
Also no movies are streamed off my primary PC so no need for optical drive.
You will most likely want to pick between a Pentium G3220 w/ a ~$100 video card and the A10 7850K w/ integrated video. Micro Center carries both.
You also have to pick between ITX and mATX. mATX will be a bit more budget friendly, mainly due to the bigger selection of motherboards. There's a size trade-off, of course.
For the PSU you probably can't beat the Corsair CX430, which you can get for as low as $20 after rebate.
For the case, look into the Cooler Master Elite 130 if you're going ITX. For mATX, look into the Fractal Design Core 1000 or Cooler Master N200.
Thank you for the reply, I was looking at the A10 7850k but the Denver Microcenter doesn't have to much of a selection on the SFF motherboards. They do have a deal on the FX-8320 for $100 which this is the following build, increasing budget a little bit:
PCPartPicker part list: http://pcpartpicker.com/p/2S4W9
Price breakdown by merchant: http://pcpartpicker.com/p/2S4W9/by_merchant/
Benchmarks: http://pcpartpicker.com/p/2S4W9/benchmarks/
CPU: AMD FX-8320 3.5GHz 8-Core Processor ($149.99 @ Amazon)
Motherboard: Asus M5A78L-M/USB3 Micro ATX AM3+ Motherboard ($54.99 @ Microcenter)
Memory: Kingston 4GB (1 x 4GB) DDR3-1600 Memory ($46.74 @ Amazon)
Video Card: MSI Radeon R7 260X 2GB Video Card ($149.51 @ OutletPC)
Case: Cooler Master N200 MicroATX Mid Tower Case ($29.99 @ Newegg)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply ($39.99 @ Newegg)
Total: $471.21
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-02-12 15:40 EST-0500)
With tax it all comes out to $548 which isn't too far off of pcpartpicker.
Couldn't find the motherboard I had picked out at Microcenter on the list though, which is actually the ASRock 960GM/U3S3.
Should I still look at a 7850k or G3220 build instead? Also not sure for video card in the price range nor good affordable power supplies. Also wondering if dual-channel memory is still better than just one stick.
Thanks for the input!
Edit: Changed to the N200 case you recommended which dropped it to $494.
If you drop down to FX 6300 you probably would not notice any difference in gaming. I would take that extra money and probably grab 8gb of ram instead.
In these tight budgets I would probably take a look at some of the combos that newegg has.
I'm not familiar with either lines of AMD's CPUs, but from a quick look at http://www.anandtech.com/show/6396/the-vishera-review-amd-fx8350-fx8320-fx6300-and-fx4300-tested/9
the FX's strength doesn't match well with your intended usage. I would much rather spend the budget on a better video card.
Take a look at http://www.anandtech.com/show/6182/fall-budget-system-buyers-guide/3 if you haven't yet. The guide is five months old, but nothing in the CPU landscape has fundamentally changed since then. Substitute FM2 for FM1 and 1150 for 1155, and the CPU section of the guide is still current. You only really need dual channel memory if you go for the A10, to feed the integrated video.
As for the video card, if you decide against the A10, and the build isn't urgent, I'd wait for the dust to settle between the GTX 750 (Ti) and the R7 265, otherwise the 260X does appear to be the best bet for now.
