Budget Gaming Build
ighardcore
Looking to start a new build this weekend. Usually I get entrenched in review articles and such for a solid month before making any purchase decisions, but I don't have that much time before I want to get this system so I ask for help from the [H].
Light gaming, particularly Minecraft, Diablo 3, and HotS.
Budget is between $400 and $500.
Norman, Oklahoma. Making a trip to Dallas this weekend with some friends to hit up a Fry's to buy this system.
I'd like a current get GPU if it can be fit in the budget, however, I have a GTX 580 I can salvage from a current system should it be required. I also have an SSD on hand, not the biggest in space but it should help bring the cost down. My previous sound card (Xonar Essence STX) should also suffice for this build, so I should be okay on that, as well. I will require a new PSU, CPU, Heatsink, MB, RAM, and Case (preferably a smaller Corsair case with room for a full length GPU), and if possible, current gen GPU. At least 8GB RAM is a must.
Samsung 930 160GB SSD
EVGA GTX 580 (if current gen GPU can't be fit in budget)
ASUS Xonar Essence STX sound card
6) Will you be overclocking?
Not interested in overclocking this build. I would like a relatively high per-thread clock on the CPU to prevent any sort of bottleneck, rather than overclocking.
30" 2560x1600
This weekend (March 7).
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
SLI/Crossfire would be nice, I like the idea of it being upgradeable, but it's not required.
USB 3.0
I have a Windows 7 64-bit license.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116991 Intel i5-4590 $200
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157511 ASRock H97 Pro4 $84
http://www.amazon.com/Cooler-Master-Hyper-212-RR-212E-20PK-R2/dp/B005O65JXI Hyper 212 Evo $35
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226612 Mushkin Enhanced Blackline 16GB DDR3 1600 $110
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013&cm_re=XFX_TS_550-_-17-207-013-_-Product XFX TS Series P1550SXXB9 550W $63
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139025&cm_re=corsair_230t-_-11-139-025-_-Product Corsair Graphite Series 230T $70
$562
or replace that 16GB of ram with this 8GB stick:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820313377 Team Elite 8GB 240-Pin DDR3 SDRAM DDR3 1600 $54
That will bring your total down to:
$506
Anything less than this wouldn't be a worthwhile upgrade over the current rig in your signature etc.
I'd stick with your 580 until you can round up another $250-300....
