budget E4300 for wife
mega72
Anyone built a budget E4300 setup lately? I'm talking like the good old celron 300 days
my wife needs a new board, cpu, memory, and power supply, she already has a nvidia 7800gtx
I tossed together a list of what's known to overclock, are there cheaper/better solutions out there? Still coming up more than I want to spend
E4300 175 $
Gigabyte GA-965P-DS3 135
cpu cooler 75 $ not sure which brand yet
Thermaltake W0101RU 550W power supply 100 $
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) 169.99 $ 5-5-5-15
Cheap out with a Arctic Cooling Freezer 7 Pro, $25 - as good as a $50 cooler.
Cheap out with a Gigabyte S3 - exactly the same as the DS3 except the DS3 uses solid capacitors.
how bout ram & power supply, there cheaper options I can go with?
She plays warcraft, it's very very cpu intensive, more than the gpu by far, I went from a overclocked amd4600+ to a core2 duo e6600 overclocked, and FPS with the same video card went from 15fps in raids, to 65fps, outdoors went from 30fps to 100fps
she's got the same problem, not enough cpu for the 7800gtx
The RAM and PSU is already pretty cheap - you may be able to find a better Fortron PSU for slightly less. I'm not a big fan of Thermaltake PSUs, I'd rather use an Enermax or Antec or almost any other brand.
If you OC that E4300 it should be OK. With my 8800GTS, I was not CPU limited with an OC'd E6300 (19" LCD res though) so it shouldn't be any worse with a 7800GTX.
we play warcraft, heavy heavy cpu usage, and both run 1920x1200 on 24" widescreen lcd's
it really kills the fps, but with a OC'ed e6600 and 7950x2 I can run all sliders at max
all she cares about is fps, sliders can stay low
E4300 175 $
Go to frys.com and wait until the Ultra V-Series 500W is on sale for "free after rebate". $9 shippinh. That is your power supply right there. Saved yourself 100 bucks.
Likewise get the Ultra Wizard mid-tower case "free after rebate" including free shipping.
Now get this Super Talent DDR-2 667 memory for $120, $50 under your budget.
That will get you up to 3000 MHz before you even start to overclock it.
http://www.ewiz.com/detail.php?p=T6UX2GC5&c=fr
Get the Zalman 9700 CPU cooler for $59, $15 less than budget.
http://www.newegg.com/Product/Product.asp?Item=N82E16835118019
It is not exactly the same as the DS3. DS3 has a different Ethernet controller, different audio controller, and a different Northbridge cooling, and also comes with 4 fan headers on it compared to the S3's two fan headers.
Which rev are you talking about? The ethernet controller may be different (makes no real world difference) but other than that they even use the same manual. Check it out:
http://america.giga-byte.com/FileList/Manual/motherboard_manual_ga-965p-ds3(s3)_3.3_e.pdf
I have Rev 2.0 the Ethernet controller, Audio chipset, and Northbridge cooler are different. And there are 4 fan headers not 2. And I have the user manual right in my hand, I can assure you it is not the same manual as the S3.
That explains it, the Rev 3.3 I linked above is the same manual.
I wont see a big performance hit using 667 ram vs 800 ram?
No, there will be very little performance hit going from 800 to 667. Certainly nothing really noticeable, like in the range of 5-10fps or more.
The advantage of 800 is that you can possibly get a higher FSB overclock with it. Depending on the 800 you get, you could possibly get 420-460FSB with non-D9 and more with D9. With 667, you're probably limited to around 400 or less.
I honestly dont think you need to waste the money on a cooler, the one the retail 4300 comes with is pretty wicked to begin with
I agree...a "budget" C2D build does not need an aftermarket cooler...the stock HSF's run well enough as is that even if you were going to overclock it you'd come away with some half decent numbers.
depends which you compare to. I haven't owned any s3's so all my specs of it are from rev1 reviews.
However, rev2 ds3's now use the same 8056 chip as opposed to earlier ones which used the 8053 nic. Not sure about memory though. Also, iirc, rev1 ds3 had only 2 or 3 leads. I'm thinking 2 but can't be certain. rev2 has 4. not sure about s3's.
it will be overclocked, for sure, 500mhz bus is the goal
so I guess I do need to get ddr 800 ram
what's D9 vs non D9?
d9's refer to micron ic's for ram. specifically, d9gmh and d9gkx are the goodies right now. if you can score that buffalo firestix on newegg for cheap still, it's a monster deal.
also, 500mhz as a goal, the ds3 should be able to hit there easily, and d9 issue has been more or less resolved. however, I feel like it'll be a whole thing of headaches, and the p5b has shown to be a much more reliable board. I can't remember for sure but it seems e4300's might be having a lower wall also if that bursts your bubble.
You need ddr 1000 ram if you're going 500 on the fsb; yes I know, some can overclock to 1000.
which asus p5b is the best bang for buck? She'll never run SLI
