If performance is not a consideration, Via C3 is fantastic. Soltek has a Qbic system with a built Via C3 1GHz: http://www.newegg.com/app/ViewProductDesc.asp?description=56-150-016&depa=0 I have a Via C3 system myself (not the Qbic I linked to though), and can attest that it is quite compatible with Windows, and does a good job running web browsers, word processors, instant messaging, etc. I have it up 24/7 as an e-mail/IM/spyware sweeper box. $180 for it, $40 for 256MB of RAM, $60 for an HDD (I'd get a Samsung), and whatever CD/DVD drive you prefer and you've got a functional box in a great package for less than $400. It would also be a breeze to move/setup at school etc and the system will be next to silent with all of the fans turned down - a 1GHz C3 only pulls ~ 12 watts. However - any CPU intensive tasks will take FOREVER on a C3 system. It performs roughly on par with a PIII 600 / Celeron 700. I wanted to open a 150MB ZIP file on my C3 - it was faster to copy it my 3GHz P4, unzip it there, and copy the extracted files back to the C3 box Also, any sort of high performance graphics are out of the quesiton - it only has a PCI slot.
blammo, best bang for the under $500 buck, and it's got upgrade potential. and if you play your cards right, you can get a 754 board and a sempron 64 bit chip
