budget build
lbonnell
10/8 update
components
case - reuse coolermaster wavemaster
psu - corsair hx650
cpu - intel e3-1220
systemboard - supermicro x9scl+-f
hba/raid - ibm m1015
memory - kingston KVR1333D3E9SK2/8G (8gb ddr3 (4x2) ecc)
have been reading the forums for a while and i am trying to decide on what components to choose for my budget build.
i was thinking to go with amd because the consumer boards support ecc however i am having a hard time finding a board with a intel nic (id rather not have to buy pci express nic and just pay for a bit more for a board with one integrated). i have no issues going with intel if the price is right. also i believe the m1015 is an x8 slot so having multiple x8 or x16 slots is a benefit so i could reuse the same board to expand capacity at a later date. if i can find a systemboard that has 6x sata ports then all the better but i will not use the onboard if it doesnt make sense to - possibly just use one or two for the boot drive
also i have just picked up the ibm m1015 as is suggested here many times.
i already have a case which while no the best for such a solution i am going to use to save money and possibly upgrade it later on when i need to expand.
i have noticed some supermicro boards support ip kvm - is this as simple as it sounds? i presume i would install some sort of software on my computer and be able to access the server / nas as if i was directly connected?
this server/nas is strictly going to be used for storage. i am not concerned about any other functionality except storing data, accessing data, streaming data.
if you need any other questions answered please let me know.
best regards and sorry about the long rant.....
luke
