Budget build recommendations
bonehead123
Hey ya'll,
I'm looking to build a new system on a low budget & would like some recommendations...
1) Not partial to any particular brand/size/style of components/cpu/memory etc.., just want something reliable & reasonably quiet.
2) Only need a basic system capabilities, no gaming, data crunching etc, just occasionally watch a online movie/video... facebook/netflix, etc plus MS office 2010 and Photoshop Elements. Monitor is a 27" 1080p Flat panel which I run at default resolution, so I will only need a modest GPU. Integrated is ok, perhaps with the capablility to add a discrete card later on.......
3) I have both HDD's & SSD's that arent that old, so internal SATA is a must. Also have newer KB & mice so thats not a concern either.
4) Would like USB 3, but not a deal breaker since most of my flash drives & peripherals are 2.0...
5) I have licenses & disks for Windows 7 Ultimate x64...so 1 optical drive is necessary
your thoughts please :-D
You probably need to answer these questions first. This will let the Gurus know exactly what you have to work with (& no I am NOT one of the Gurus). Try to be specific (brand and model) on the parts you are planning to reuse. HTH
This is a copy of what I wrote on another forum.
On the theme of budget, here's a general idea (don't own these parts so I can't vouch for their reliability but you can always check amazon and newegg feedback etc.):
Gigabyte GA-H87-D3H motherboard $90 to $100
http://www.amazon.com/gp/product/B00CU4L3AU
Intel Core i3-4330 processor 3.5 GHz 4 MB cache $130 to $137
http://www.amazon.com/gp/product/B00EUUN76U
EVGA GTX 750Ti video card (or another one if the fan is too loud) $140 to $150
http://www.amazon.com/gp/product/B00IDG3PRI
and 8 GB of RAM which might be around $80 (you could check newegg reviews to check what's compatible with the motherboard).
So $90 + $130 + $140 + $80 = $440
(Even though I'd prefer a quad core like the i5-4440 $180 for a total of $490)
http://www.amazon.com/gp/product/B00EUUIWZ6
Gee, that comes out more expensive than I thought. :eek:
EDIT: I also prefer video cards with heat pipes in case there's a fan failure but the ones I quickly looked at were a bit expensive.
Microcenter has the i5 4670K for $189.99 if you have one close, should be best bang for buck under $200.
Highly recommend this if you live near a Microcenter:
$200 combo Kaveri A10-7850K, Gigabyte GA-F2A88XN-WIFI 802.11ac mATX and Battlefield 4
$100 8GB (2 x 4GB) Radeon DDR3-2400 straight from AMD/Dataram after ASRock $20 off promotion code.
Optional but recommend $50 Noctua NH-U9B SE2 push-pull air cooler and request for free NM-90A kit.
You can reuse power supply and case since mITX mobo fits in mATX or ATX case. I ended up buying a handsome Fractal Design mATX case for $29 and reused an extra Seasonic 650W bronze.
System is surprisingly very zippy with CPU performance bettering my dual-socket Xeon 5160 by almost double in Winrar at ~3700 KB/s vs ~2100 KB/s. In BF4 it does ~43 fps average at 1080p low with Mantle or ~60 fps at 1600x900.
100% stable, runs cool and virtually zero noise.
