Budget build opinions?
Loading
Budget build.
Hello all,
Currently my computer is eons old. Barton 2500+ 1 gig ram, some random video card I can't even remember, 2x120 drives in raid 0. Not worth upgrading at all, I think I'll turn it into my home theater computer.
I'm not that serious of a gamer, so for now I think I should be able to scrape by with a fairly budget build.
OCZ GameXStream 700W ATX12V 24PIN SLI Ready Active PFC ATX Power Supply 120MM Fan Black
* Usually Ships in 1 to 2 Business days.
* $25.00 CAD Mail in Rebate for this item - click here
Yes $142.61 $142.61
Yate Loon D12BL-12 120MM Quiet Cooling Fan 1200RPM 45CFM 24DB 3PIN & 4PIN Ball Bearing Oem
Yes $2.89 $2.89
Coolermaster CAC-T05 Centurion 5 Aluminum ATX Tower Case 5X5.25 1X3.5 4X3.5INT SILVER-BLACK No PS
Yes $50.22 $50.22
EVGA E-GEFORCE 8600GTS 675MHZ 256MB 2.0GHZ GDDR3 PCI-E Dual DVI-I HDTV Out DIRECTX10 Video Card
Yes $218.72 $218.72
Corsair XMS2 TWIN2X2048-6400C4 2GB 2X1GB PC6400 DDR2-800 CL 4-4-4-12 240PIN Dual Channel Memory Kit
* $50.00 CAD Mail in Rebate for this item - click here
Yes $187.20 $187.20
Seagate Barracuda 7200.10 500GB SATA2 3GB/S 7200RPM 16MB Cache NCQ Hard Drive
Yes $137.99 $137.99
Gigabyte GA-965P-DS3 Atx LGA775 Conroe P965 DDR2 PCI-E16 3PCI-E1 3PCI SATA2 Gblan Audio Motherboard
Yes $145.88 $145.88
Intel Core 2 Duo E6420 Dual Core Processor LGA775 Conroe 2.13GHZ 1066FSB 4MB Retail
Yes $208.88 $208.88
Shipping & handling $0.00
Insurance $16.42
Sub Total $1,094.39
6% GST $66.65
7% PST - BC residents $77.76
Total $1,255.22
Am I missing anything completely obvious? This really didn't end up being a budget build.. Oh well, it'll keep me good for a good long time.
How's the motherboard?
I hate the damn mail in rebates, I always forget to send the damn things in, but it seems as if all the ram on that site right now has mail in rebates on ram.
Not certain if I'll be overclocking. Do these procs overclock ok on stock cooling?
Could someone recommend a real budget build? Perhaps more along the lines of 700ish after tax, and is a 700 CAD computer enough to get me by, with some options to upgrade?
Thanks.
My buddy is using the stock HSF to get to 3.0ghz and he only has to raise the voltage to 1.4.
Since you abandoned the budget build status, you should cough up an extra $70 or so and pick up a 8800gts 320mb. The performance difference will be substantial.
Drop the GXS 700W. It has ripple... and ripple kills your parts over time. Ok, so it most likely won't, but would you want to take that chance? Play it safe and go for something else. Here are some recommendations:
http://www.jonnyguru.com/forums/showthread.php?t=1460
http://www.jonnyguru.com/forums/showthread.php?t=103
The 8600GTS is overpriced. Do you need DX10 support? Because there aren't any current DX10 games. What size monitor do you have?
If they have any G.Skill ram, check to see how cheap it is. They're pretty good sticks, and are usually priced similarly to the Corsair's After Rebate price.
Yes, these chips OC nicely on stock cooling, too. On stock, you should be able to reach 2.8-3Ghz. The DS3 is one of the best boards out right now.
Where do you shop for your parts? Where are these prices from?
I put together a machine for $640US shipped (after rebates) less than a week ago. Everything but the case is here so I can't vouch for its performance first hand but I imagine it'll be quite good for our needs (little to moderate gaming).
Using today's US to Canadian converter it should come out to about $708 canadian assuming you can find a canadian retailer who is able to match newegg's prices.
Case:
Eagle Tech ET-CASW2-WOP-BK Black Steel ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811117086
Power Supply:
XCLIO GOODPOWER 500W ATX12V 500W Power Supply 115/230
http://www.newegg.com/Product/Product.aspx?Item=N82E16817189005
CPU:
Intel Core 2 Duo E6420 2.13GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115016
Motherboard:
ABIT IB9 LGA 775 Intel P965 Express ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813127018
RAM:
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231098
Video Card:
EVGA 256-P2-N615-TX GeForce 7600GT 256MB 128-bit GDDR3 PCI Express
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130062
Hard Drive:
Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148140
CD/DVD:
LITE-ON, DVD/DVD-RW/CD/CD-RW Combo
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106070
