Budget Build - Moderate Gaming
Puriden
Moderate Gaming (probably SC2), Web Browsing, Light Video Editing
$550 w/ tax & shipping
3) Where do you live?
Houston, TX
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
Case, PSU, MB, CPU w/ heat sink, GPU, RAM, HDD or SSD, DVD
Monitor, keyboard, mouse
6) Will you be overclocking?
Not Likely
22", Reuse
Now
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
No, but may purchase separately via student discount if not combo'd
$505 build man
OCZ Special Ops Edition 4GB DDR3 1600 + HIS Radeon HD 5770 1GB both for $204.98 ($20 MIR on RAM, $10MIR on video card)
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.443051
AMD Athllon II X3 Rana 440 for $76.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103843
MSI 740GM-P25 AM3 AMD 740G for $49.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130288
SAMSUNG Spinpoint F3 HD502HJ 500GB for $54.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152181
LG 22x Sata DVD Burner for $17.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136180
CORSAIR CMPSU-400CX 400W for $49.99 ($20 MIR)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139008
COOLER MASTER Elite 341 for $39.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119193
Total: $494.92
Shipping: $10.73
Grand Total: $505.65
Check TigerDirect for CPU/Motherboard combos. AMD is dirrrrt cheap.
Thats a solid built above but Id recommend getting a better motherboard and trying to get a 500 watt PSU if you can. 400 is plenty but 500 will leave you some room for future upgrades.
The thing about the motherboard is, if you spend extra on it now youre set for upgrades later. You can upgrade a GPU, CPU and RAM just by dropping them in. You want to upgrade your motherboard and you have to pull everything out, re-install it then re-install Windows. Better to pay $40 more now.
$505 build man
Total: $494.92
Shipping: $10.73
Good build but since you got budget to spare I'd say upgrade the CPU to this:
$140 - AMD Phenom II X4 945 Deneb 3.0GHz
or atleast this:
$88 - AMD Phenom II X2 550 Callisto 3.1GHz
Both are a bit better for gaming, although the X4 might be too much over budget.
or atleast this:
I just picked up a Phenom II X2 555 black ($99) and unlocked it stable to a Phenom II X4 B55 @3.2ghz (LOTS of overhead for OC on stock cooler..idle@37C). I suggest trying to unlock and free up some money for ram or GPU
I like the motherboard idea. What do you think about this instead or is this wasteful for the few minor feature upgrades?
$95 - GIGABYTE GA-785GMT-USB3 AM3 AMD 785G USB 3.0 HDMI Micro ATX AMD Motherboard
Let's see here. The advantage would be
-More RAM support. 16GB total (4 x dimm slots)
-Mobo uses all solid state capacitors
-A newer AMD 880G chipset with a faster Radeon HD 4200 IGP
-USB 3.0 support
-2 x PCI slots vs 1 on the MSI
-1 x eSATA 3Gb/s
-1 x IEEE 1394a
-1 x Optical
-HDMI out on the mobo
Could you stretch your budget to something like this MSI 890GX board for $130 shipped?
This is a very solid board that will work great for future upgrades and will handle serious overclocking with no problem. Itll take a 140 watt CPU so you can do some serious cranking on your overclock and this thing will be fine. Youll be able to upgrade over and over again without having to worry about a motherboard.
I see where you are going with it and it is a good board, but not sure I want to stretch outside my range. Also, I doubt I'll overclock unless I get bored one afternoon. I do like the Gigabyte offering USB3.0, eSATA and as HardwareGuru pointed out, the newer chipset and solid state capacitors which I wasn't much focusing on when I reviewed it.
Appreciate the help guys. Just need to pull the trigger on the Gigabyte or the original MSI mobo which was recommended.
Hmm.. I probably would settle for this MSI mobo
MSI 880GM-E41 AM3 AMD 880G for $74.99
It's good enough already. It has all solid state caps, a newer 880G mobo chipset, 4x dimm slots, HDMI out.
No sense spending too much especially someone asking for a $550 budget.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130295
Antec NEO ECO 520C 520W $59.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371030
Total: $529.92
Shipping: $13.64
Grand Total: $543.56 Still under your $550 budget. I just improved the mobo with a more robust one and increased the PSU to a more powerful one to 520watts for more headroom.
I like that build. Without overclocking at all, youll be able to max out nearly any game at 1680x1050 and a lot of them at 1920x1080. All for less than $550. And I agree, that is a very good, solid motherboard especially for the price.
That's a good build as well, but I seem to be hung up on the on-board USB 3.0 for a likely DSLR or camcorder purchase in the next 18 months (baby talk with the wife has begun). I doubt I'll do much if any upgrading (unless components die on me), so I think the 400W will be sufficient over the life of this machine.
Gigabyte w/ Corsair 400W:
Total: $539.92
Shipping: $5.89
Grand Total: $545.81
Let me know if you think I'm off my rocker though! :)
I agree about your PSU choice, the 400CX is a really good PSU and can easily power that system. Otherwise HWGuru's build should fit you well.
Total: $539.92
Shipping: $5.89
That's a good choice also. The Corsair 400CX may not be as powerful as the Antec but, $50 upfront with a $20 MIR that's hard to pass up.
