budget build challenge
paco
Ok, who here can help me with a budget build? I'd like to build a machine with a Core 2 Duo processor or equivalent, and 1Gb of RAM for $600 or less. I need everything but a monitor basically. They will be doing most surfing, spreadsheet work, and a lot of picture editing and printing. So no overclocking is necessary.
Heres the rundown of what the person wants/needs...
mobo
cpu (core 2 duo preferably, or equivalent)
1Gb RAM
250Gb HD or bigger
2 DVD burners
card reader
floppy drive
modem - hopefully will be onboard
case (a simple mid tower case)
power supply
video card
Thanks to whoever replies.
Too bad the FAR case and PSU from Fry's is not "on" right now.
//edit: Sorry, I didnt have time to link those parts earlier... here you go:
$163 - Intel Core 2 Duo E4300 Allendale 1.8GHz 2MB L2 Cache
$105 - Biostar TForce965PT LGA 775 Intel P965 Express
$67 - Patriot Signature 1GB (2x512MB) DDR2-667 PSD21G667K
$53 - WD Caviar WD1600JS 160GB 7200RPM SATA300 8MB Cache
$30 - Cooler Master RC-534-KWN1 Black Centurion Steel Mid Tower ATX Case w/ Side Window
$38 - XClio 450BL ATX 450W
$29 - Lite-ON 18X DVD±R DVD Burner IDE Black LH-18A1P-185
$30 - Freetech PX6200TD-128M GeForce 6200 128MB ($40 - $10MIR)
$515 + tax and shipping (after rebates)
With the brisbane combo, it would be even cheaper:
$150 - COMBO: AMD Athlon 64 X2 3600+ + BIOSTAR TFORCE 550 Socket AM2 ($24 combo discount)
$85 - Wintec AMPO 1GB (2x512MB) DDR2-800 3AMD2800-1G1K-R
$30 - Zalman CNPS7000B-ALCU 92mm CPU HSF (Quiet)
Add in the other parts from above for a total of $445 before tax and shipping, after rebates.
You could probably bump it up to 2GB instead. Comes out to $530 before tax and shipping... so its up to you, if it fits the budget:
$170 - G.Skill 2GB (2x1GB) DDR2-800 F2-6400CL5D-2GBNQ
