Hello all,
I'm helping my dad to select parts for a new PC, and his budget for CPU+Mobo+RAM is about $500. There will be no gaming, just "regular" windows stuff, however he does want DVI-out. Snooping around I came up with a few preliminary configs (all prices in CAN $):
Option1: Budget AMD
CPU: X2 6000+ $185
Mobo: Asus M2A-VM (microATX...) $69
RAM: Corsair 2x1Gb DDR800 5-5-5-12 $95 (after $30MIR)
No GPU required (integrated graphics and DVI-out on mobo)
Total with 6% tax: $370
Option2: Budget Intel
CPU: C2D4400 $160
Mobo: Intel DG33FB $115
GPU: MSI NX7100GS-TD128 with DVI $40
Total with 6% tax: $435
I've never built a microATX system before which is why I have absolutely no idea if the Asus config for the AMD makes any sense for a regular-sized case. Any inputs? If it would work, I'd of course consider the same thing for the intel config...
Thanks!
Option1: Budget AMD
CPU: X2 6000+ $185
CPU: C2D4400 $160
Thanks!
