Bubbles in EK-FC block?
thatguyX
I'm new to WC and I'm currently leak testing a GPU loop i put together all seems well so far 3 hrs in and no leaks. I'll wait a little longer maybe 6 or so... but anyway, I can see tons of tiny bubbles in my res (XSPC res for teh Swiftech MCP350), and also in the EK block for my GTX285. I'm using 500mL of pure Feser VS.C. I am currently leak testing with the res cap off to vent. The loop is XSPC Res>Swiftech Pump>XSPC RX120>EK block> Res
Is this normal? I've tried moving everything around tilting back and forth but the bubbles in the block just never go away. It also looks like there's a pocket, where some bubbles are just swirling in circles.
Try tapping the block with your finger to dislodge the bubbles. If that doesn't work, use the end of a screwdriver and tap lightly. That's how I got rid of the bubbles in my radiator.
Totally normal. Regular light tapping here and there while it's running, as well as the actual flow of the loop will eventually get the bubbles worked out.
Good luck with your rig.
It took almost a day of running continuously, with me shaking and tapping everywhere, to get the last of the bubbles out of my ek fc blocks. It seems normal, they just stick in there for some reason. Just keep bleeding, and look at it this way - it forces you to leak test for longer, which is always a good thing.
well i gave it an 6 hour leak test and then my psu would not stay on when i jump started it, so i decided to just throw everything in and start it normally with paper towels and little plastic bowls under anything that could leak. The system ran overnight and I when I woke up everything was running fine and no leaks. That should be good then right? The bubbles have cleared out of the block, but there are still mini bubbles in the res, that's ok though, right?
So far everything seems to be good, the gpu idles around 35C and the highest i've seen on load (CoD:WaW for about 2 hours) is 50C with an ambient of about 27C. Much better than the 80C, I was seeing with the stock cooler. Since this went pretty well I'm now considering expanding the loop with an RX240 (or if I can fit it nicely, an RX320) mounted on top in conjunction with the RX120 and maybe throwing in a CPU block. I guess now that my GPU is quieter (except for the Noctua pulling through the rad at full 1300rpm), the CPU fan (Zalman CNPS 9900) seems louder than before. But the idle temp is now at 45C as opposed to the 35-38C it used to be. I assume that is because I replaced the intake fan with the rad setup.
The mini bubbles in the res will go away with time. The bubbles are fine as long as they're not getting sucked into the pump. Even if they are they'll eventually work their way out of the system. Sounds like your setup is good to go.
Hehe that's how the addiction starts. First it's one component... then another, and it goes on from there.
does anyone get bubbles while stress testing? i think when i was running prime95 for hours testing my 4.0 i7 overclock i started to get bubbles in the res again. anyone else ever get this? not trying to steal the thread, just a similar topic.
