1 Watt = 3.413 BTU
1 Ton = 12000 BTU = 3516 Watts (or the equivalent of melting 1 ton of ice per hour)
There are sensible vs latent heat load calculations to do, but for most locations that don't include anything that adds heat/humidity (windows, air leaks, appliances, people) you can rate your folding room's cooling requirements by using 75% of the rated cooling capacity of the cooling unit.
A 1 ton unit (12000 BTU) should be able to handle 2500 watts (8533 BTU) of heat generated. This is rarely a cut and dry situation, but since this is a subject important to us, and we have few HVAC prefessionals to help us on the forum.
Many things will influence the cooling requirements (windows, sun, humidity, etc) but this gives you a starting point to size your cooling. Whether you use BTU, Watts or Tons as a point of reference you at least have some idea where to start.
The sensible heat calculation is as follows:
hs = 1.08 q dt (1)
where
hs = sensible heat (btu/hr)
q = air volume flow (cfm, cubic feet per minute)
dt = temperature difference (oF)
I am not an HVAC engineer, and they would do a much better job of calculating what you need....but most of us are folding on a budget...we can't afford a full blown analysis.
Hope this helps. Anyone in the industry who wants to help would be welcomed.
hs = 1.08 q dt (1)
where
