BSOD
speedrat
I am getting random BSODs including 1 and 24. Ran Memtest, chkdsk, reformatted and still get these crashes. I have latest video drivers, running stock onboard audio drivers, and default MB drivers with no OC. I will post test results and dmp files tonight when I get back home . I posted this as is so I could at least get my specs checked out...You know...get past the "hey dumbass...you can't put that memory with that MB, etc"...Any help would be greatly appreciated. I'm kinda at a loss....
ASUS P8Z68-V PRO LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
EVGA 012-P3-1570-AR GeForce GTX 570 (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I72600K
CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ16GX3M4A1600C9B
ZALMAN CNPS9500 AT 2 Ball CPU Cooling Fan/Heatsink
Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
LIAN LI PC-A71F Black Aluminum ATX Full Tower Computer Case
Corsair HX1000 PSU
Windows 7 Pro 64 SP1
Do you still get BSODs with only 2 sticks of memory?
Have you tried booting the mobo/cpu/etc outside the case?
Generally, in my experience, if you have done all the basics..basic build with basic required stuff inside, start putting stuff back in one at a time, test the memory 1 stick at a time in each slot. then unless you've grounded your board somewhere by mistake, the problem is almost always the PSU or a voltage issue with the PSU.
my 2 cents
