BSOD with Mirror's Edge?
TIWizard
I have a 4870 X2 with the latest 9.8 drivers, but after playing Mirror's Edge for about 10 minutes, it freezes then goes to a BSOD...
Previously with 9.7 drivers, Mirror's Edge would just freeze and if I would Alt-Tab out and close the process quick enough, Windows would say that the display driver stopped responding and has recovered. Otherwise, my computer hangs and I have to force it off...
Anyone else have issues?
Win 7 RTM
4870 X2 with 9.8 and 9.7 Drivers
do you have the lastest Mirror's Edge patch?
what PSU do you have btw?
Now would be a good time to make sure the fan is working and blow out the dust on that card.
As leSLIe suggested, your PSU might be causing it also.
I see it's a liquid cooled card in your sig. Make sure it's getting fed cooled liquid.
I actually do not know what PSU, but from what I have heard, it is a 1000w PSU...
I don't have issues in any other game than Mirror's Edge (Crysis runs on max 1920x1200, 8xAA)
I am sure that the card is being cooled properly :)
Maybe try re-patching or reinstalling it then since it's the only game you're having a problem with.
Yeah, I have tried that many times... I will do it again to be safe. It seems like I am the only one that is having the problem though... Odd...
Does it auto update, or are you installing a patch you've downloaded?
If you downloaded the patch, might be worth a redownload incase the patch was corrupted.
It was autodownloaded by the download manager.
