BSOD on new system
  • Thread starter Deleted member 68403
  • Start date
D
Guest
Hey all. Well I decided to upgrade. I bought a Gigabyte K8N Pro SLI motherboard and a 7800gt video card to replace my Asrock 939 board. The install went fine and I was confident that I would never see a BSOD again. I was wrong. I am getting the same BSOD at random intervals on my new computer: MACHINE_CHECK_EXEMPTION. I researched this error on Microsoft's website. It says it is caused by an unstable overclock, an inadequate power supply, bad system chipset drivers, or bad memory. The system is not overclocked in any way, so that rules that out. I have an Antec 550 watt and Antec 480 watt power supply and it happens with both power supplies, so I think we can rule that out. I ran memtest86 last night for 12 hours and there were no errors, so I think I can rule that out. The only thing left would be bad system drivers or something else. I used all the drivers off the CD that came with the motherboard. Here's what is listed in the system event viewer after the computer crashes:
Error code 0000009c, parameter1 00000004, parameter2 8054d370, parameter3 b2000000, parameter4 00070f0f.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Any ideas? Thanks
i would try different ram and also upgrade drivers to the 6.70 off the nvidia site.
did you put a fresh install of windows down with this new mobo?..its got to be something you used in both systems.if its a fresh install of windows and your running the latest nf4 drivers with no nvidia firewall or network manager installed,i would swap ram if you have any.or just try increasing the ram voltage a bit.ive had systems do odd things and ram cks good and still swap ram and all problems went away.
Yeah, I did a complete format on the hard drive when I upgraded the motherboard. I will try upping the vdimm and trying some different memory and seeing if that eliminates the BSOD. If I download the newest nforce drivers off of nvidia's website, do I have to uninstall the chipset drivers I already loaded or can I just install them without uninstalling first?
UPDATE: Well, it's either my memory or my SATA2 hard drive. I'm leaning toward the hard drive. I turned off my fans and noticed that everytime I get the BSOD, right before it happens, my SATA2 hard drive makes a single click sound which is followed by the BSOD. I downloaded and ran Windows Memory Diagnostic in extended diagnostic and it passed with no errors. But I also ran Data Lifeguard on my hard drive and chose the extended test and my hard drive passed with no errors.
Well I got it figured out. You'll never believe it, it was my TDK CD Burner. I was going thru the system event viewer and I saw an error on the TDK Drive. So I disconnected it and ran my system into the ground over night and came home this afternoon and it was still going strong.
So it booted when you unplugged the burner? cool well glad it worked out :)
That's very interesting.
0x9C is a MCA exception.
Was this TDK burner attached to a PATA port, or a SATA port? I'm a little surprised such a device could cause a MCA fault.
The TDK was attached to the PATA Secondary Channel as a Master. Since I removed it, my computer has not had the BSOD.
That is interesting, I had an HD that was doing the same thing: it would start clicking, then I get a machine check exception, but the event viewer pointed to something else :rolleyes: replaced the HD and it stopped completely.
That sucks, sorry the mobo switch didn't fix the BSOD. I was having a similar issue with my Abit AX8 pretty often. I can't remember the error, but it was USB based I think (something with my hub or whatnot). Luckily I did fix it by getting an Abit KN8 (or K8N - naming conventions have me confused). Since the NF4 mobo I haven't gotten a single one.
Um, my AX8 was a SATA HDD killer... Any HDD connected would die within 10 minutes.
