BSOD on new build
skagen
I just bought some new components for my dad's computer. when trying to install windows, i got the BSOD and something about windows detected something and is shutting down to avoid problems.
New
ThermalTake 430 PSU
CPU - pentium d 805
abit ib9
1 gig (2x512) Geil DDR2 800
SATA drive
I've tested the CPU with another CPU, testing 3 different motherboards, tested working OCZ ram with same speed and tested it with my raptor. It works with the raptor, booted up and everything was dandy. i CANNOT boot using an IDE HD either as those crash in the middle of the installation process as well.. (computer just shuts off). Please help!
which sata drive? whats the error code? how did you test the ram, did you run memtest? if not, you should. did you try another PSU? did you try another cable? another optical drive?
