V-e-l-o-c-i-t-Y
- Jul 17, 2005
Cant figure out why my pc keeps bsoding. It is not saving any log files in the minidump folder. I figured the issue was the motherboard as before it would bsod then it would not reboot correctly so it would not save a minidump. But I just swapped the motherboard and it is still giving me issues. I ran memtest for about an hour with no issues. Just cant figure this out, and its driving me crazy.
It is blue screening on a fresh install of windows 7 ultimate, and the drivers are all up to date.
System Specs
i7 930 Bloomfield
Evga x58 SLI 3x (was an Evga x58 SLI LE when the issue started)
12gb patriot ddr3 1600mhz
evga 470 gtx
kingwin laser 1000 watt psu
Intel and Crucial SSD
Samsung and a seagate standard 7200 rpm 1tb and 500mb drives
Coolermaster h50
LG BD Burner
I do have the event log record if anyone is good at diagnosing these this is about the only thing that actually logs:
- System
- Provider
[ Name] Microsoft-Windows-Kernel-Power
[ Guid] {331C3B3A-2005-44C2-AC5E-77220C37D6B4}
EventID 41
Version 2
Level 1
Task 63
Opcode 0
Keywords 0x8000000000000002
- TimeCreated
[ SystemTime] 2012-10-11T16:17:51.819609300Z
EventRecordID 1481
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 8
Channel System
Computer Computer1-PC
- Security
[ UserID] S-1-5-18
- EventData
BugcheckCode 0
BugcheckParameter1 0x0
BugcheckParameter2 0x0
BugcheckParameter3 0x0
BugcheckParameter4 0x0
SleepInProgress false
PowerButtonTimestamp 0
System Specs
i7 930 Bloomfield
evga 470 gtx
Coolermaster h50
LG BD Burner
- System
- Provider
EventID 41
Version 2
Level 1
Task 63
Opcode 0
- TimeCreated
EventRecordID 1481
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 8
Channel System
- Security
[ UserID] S-1-5-18
- EventData
BugcheckCode 0
