jamespetts
- Nov 8, 2007
I have just put together a new computer (specs below), but am having a rather odd difficulty about which I have not been able to find information via a Google search: whenever I try to update my graphics card drivers, I get a BSOD error making reference to atikmpag.sys. The graphics drivers that came on the CD with the card work, but they have a date sometime in 2009. Installing the drivers either using the setup executable downloaded from the ATI site (the Catalyst Control Centre installation package) or using the built-in "update driver" function in device manager results in a BSOD part-way through the upgrade process. When the system reboots, the backup VGA drivers are loaded and Device Manager reports that there is an error with the driver for the graphics card, although gives the correct date for it (25th of November 2010). This error happens consistently. Rolling back the driver to that with a version 8.660.0 (8th of September 2009) allows the system to work again, but with the out of date graphics driver.
The specifications are:
Intel i7 950 @ 4.11Ghz
GA-X58A-UD7 motherboard
6Gb RAM (triple channel kit, 3x 2GB)
Windows 7 64-bit
PowerColor PCS+ Radeon HD5780
Any help would be much appreciated!
Windows 7 64-bit
