BSOD and slow load, XP
GZS
To make a long story short, (It might end up still being long) I was using my desktop yesterday. It locked up when I was loading a map for COD4. It's never locked up on me before, so I freaked and hard-reboot it.
When it went to load Windows, it said "NTLDR is missing, press ALT + CTRL + DEL to restart".
I went through the system recovery console and replaced NTLDR and NTLDRdetect.com manually. It still didn't fix.
I reinstalled windows without reformatting so I could save a few things I wanted. Once those were saved, I turned my computer off and switched the SATA cables for my hard drives. I have previously had my primary in SATA slot 2 and my secondary in SATA slot 1. I just switched the order in Bios as opposed to opening my case. I figured, while I was fixing things, I'd been meaning to do that.
After the cables were switched, I reformatted and reinstalled windows (XP SP3).
I got into windows last night, but Road Runner sucks and crashed for about five hours, so I left it sitting all night without any drivers. This morning I get up and begin installing drivers. I finish all of them and start installing my programs. The order I installed them-
Firefox, Thunderbird, AVG, Trillian, VLC, Steam (Along with my steam games) Richard Burns Rally, Live For Speed (Stand alone, copied from my second hard drive).
Now, After getting Thunderbird installed, I BSOD'd. I figured it was because I was installing five programs at once and thought nothing more of it.
Just surfing, another BSOD.
I check into my system event viewer and no error pertaining to the install, but it says that my D drive is giving errors. I've deduced that the SATA cable is bad, or going bad and will replace it when I finish writing this... but would a bad SATA cable on a secondary hard drive cause BSOD's? What else could be going on here to piss on Windows? It's taking about 2 minutes to get past the title screen (With the bar scanning).
Specs:
Q6600
4 gigs A-Data 667
Asus P5N32-E-SLI
Lite-ON dvd burner
2x 500 gig WD's
EVGA 9600GT
Some other stuff?
Go to Hitachi's Site and download Drive Fitness Test. Then burn it as a bootable disk. Most likely one of your hard drives is bad. And yes, a secondary hard drive will definitely cause BSOD's if there are bad/corrupt sectors.
Run the software on both of your hard drives, also download and run MEMtest for about 8 hours on each stick of RAM. You have some kind of hardware issue. If you want to be a little more thorough, check your motherboard for blown capacitors or bulging caps.
It was the SATA cable, or port. I switched the cable and port and it's not loading like a snail. No BSOD's yet...
I tried to put that Drive Fitness program onto a flash drive, with no success. I don't have any blank CD's, if it happens again I'll have to head to the store and get some.
Thanks again!
This was the error by the way. I'm not getting them anymore.
Code:
Event Type:	Error
Event Source:	Disk
Event Category:	None
Event ID:	11
Date:		9/5/2008
Time:		9:06:46 AM
User:		N/A
Computer:	GZS-DESKTOP
Description:
The driver detected a controller error on \Device\Harddisk0\D.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 03 00 68 00 01 00 b6 00   ..h...¶.
0008: 00 00 00 00 0b 00 04 c0   .......À
0010: 03 01 00 00 00 00 00 00   ........
0018: 00 00 00 00 00 00 00 00   ........
0020: 00 00 00 00 00 00 00 00   ........
0028: 81 2c 00 00 00 00 00 00   ,......
0030: ff ff ff ff 07 00 00 00   ÿÿÿÿ....
0038: 40 00 00 00 00 00 00 00   @.......
0040: ff 20 0a 12 48 02 20 40   ÿ ..H. @
0048: 00 10 00 00 0a 00 00 00   ........
0050: 00 00 02 00 e8 8d b9 8a   ....荹Š
0058: 00 00 00 00 b8 8b b9 8a   ....¸‹¹Š
0060: 00 00 00 00 af 77 1d 1d   ....¯w..
0068: 28 00 1d 1d 77 af 00 00   (...w¯..
0070: 08 00 00 00 00 00 00 00   ........
0078: 00 00 00 00 00 00 00 00   ........
0080: 00 00 00 00 00 00 00 00   ........
0088: 00 00 00 00 00 00 00 00   ........
Good to hear everything is working better for you, if you get a chance I would still run a DFT on it to be safe.
Cheers! :D
