Okay, my family and I picked up a bunch of parts to use to rebuild my younger brother's gaming rig for Christmas; however, I'm having some really frustrating problems. Basically, I would get a BSOD when installing Windows (XP Professional) on his computer (during the 'copying files' phase after reformatting). In an attempt to isolate the problem, I updated the motherboard's BIOS, changed out the video card, and even used a different optical drive for the windows installation. I changed out the memory with an extra set of XMS modules that I had sitting around and it solved that BSOD issue...but then it started locking up during the actual Windows installation (BSOD once and locked twice). Now, I know that the XMS modules that I put in are good because they came out of my gaming rig a couple of months ago when I bought new RAM, so I don't think that the RAM is the problem.
I have been able to coax the computer into actually loading up to the windows desktop a couple of times but it either locks up whenever I do anything or throws a BSOD before even getting past the login screen. At this point, I'm starting to get stuck and it's rather frustrating...suggestions?
System specs for the troubled box:
CPU: Sempron 2500+
Mobo: NF7-S2G (using BIOS 13)
Video Card: BBA Radeon 9800Pro
RAM: 1GB (2x 512MB) Corsair ValueSelect PC-3200 (currently have 512MB (2x 256MB) Corsair XMS PC-2700 C2 in the computer as mentioned above)
Timings: was running the ValueSelect at 11-3-3-2.5 (@ 1.6 & 1.7v) - currently running the XMS at 11-3-3-2 @ 1.7v
PSU: (also new) Vantec 350w Ion2 (400w peak load) PSU
HDD: Seagate (7200.7) 120GB 7200RPM ATA100 8MB cache
Aside from the video card, HDD, optical drives, floppy drive, keyboard, mouse, and monitor, no additional devices are connected to or installed in the computer.
Thanks in advance!
*edit* Update: The XMS (which had survived multiple 24 hour memtest runs and Prime95 runs in my rig) and the ValueSelect have both been subjected to about 4 hours of memtest in this rig without any errors. Vcore and vdimm were increased previously (vcore was increased by 6% according to the BIOS and vdimm from 1.6v to 1.7v) chipset voltage was also increased to 1.664v. The computer throws a BSOD about 95% of the time when you try to boot into windows.
As for some other information, the CPU seems to idle at around 34C...though, it's rather odd that the BIOS doesn't seem to be picking up RPM readings from ANY of the 3 fan headers (as there are fans plugged into all 3 and all of the fans used support RPM monitoring).
The voltage rails seem to be doing okay:
+3.3v | +3.29v
+5v | +5.08v
+12v | +11.91v
The rest of the misc. voltage information is either dead on or within about + or - 0.02v
I have noticed, though, that the mobo makes a quick chirp about a second before the normal POST beep. It has done this on every power up, including the first IIRC.
CPU: Sempron 2500+
Thanks in advance!
+3.3v | +3.29v
+5v | +5.08v
+12v | +11.91v
