BSOD 124
smokin9
Not really sure where to put this but since this might pertain to my o/c on my p8p67 i figured here...
I get this BSOD 124 randomly sometimes. I got it once when I was actually using the computer but the other 2 times I got it I had just gotten home and the comp was off so it wasnt doing anything but idling.
What does 124 usually mean? Is it my o/c do I need more voltage? I mean my comp isnt even stressed when it happens 2 out of the 3 times. A driver? I know sandybridge is fairly new are the chipset drivers 100% stable? I would assume so. I just want to know where I should start looking...
I can sit here and play games for hours without a BSOD so its kind of strange, I've also ran p95 for about an hr without any problems.
Who knows really .
But if it were me i would shave off a little speed on your overclock .
You know slow the cpu\ram\hole deal down a little bit and just see what happens.
A BSOD code of 124 means that you have to change the VTT (Uncore voltage) setting. This BSOD can occur if the VTT is set too low or too high, so you might have to play around with that setting in small increments.
not necessarily.
OP: Are you using "Load Line calibration"? Is your board RAISING the voltage at load, compared to idle/BIOS voltage?
not necessarily.
I assumed that "Load Line Calibration" is set to "Low Vdroop" or similar. Also, different boards do strange things under load.
Anyway, insufficient CPU core voltage would have resulted in a BSOD error code of 101.
124 can also mean VCore, but usually its VTT.
Try to bump a notch on each voltage and test, do them individually so you know which one needs it.
Use the Linpack test in OCCT or in LinX/IBT with max memory, it will find if you're stable faster than Prime will. Always watch temps when stresstesting.
Yep, it can mean either.
I can stop prime blend from bsoding at 5 ghz by either increasing vcore or VTT. Since small FTT passes but blend doesn't, that's because I'm unstable at lower loads since I'm using LLC.
not necessarily.
Actually my Load line calibration is set to ultra-high.
My cpu voltage is set to 1.35 running at 4.5
So I should go about adjusting my vcore and vtt?
Yeah, LLC at Ultra high will always call BSOD 124's at idle or in Prime blend, if the BIOS vcore is too low, when Linpack or Small FFT will pass for hours, because you're unstable when the CPU is at lower load, but at higher load, the vcore goes up, thus making you "stable"...
Both Vcore and VTT will help stability. But use whatever one raises heat the LEAST. If +0.05v-0.10 VTT stabilizes you, and keeps heat lower than +.03v vcore, then by all means use that. Lower vcore is always better.
There's no one solution fits all, though. You just have to experiment to find out what works best for your CPU.
It's probably easier to reduce the loadline level, though. Ultra high overshoots the volts to have your load vcore higher than your idle, by about 0.04v, is that correct?
Raising your idle voltage a bit while lowering your full load will help avoid the lighter stress BSODs easier. Though, you will need to know the vcore required for stability at maximum load.
