praziquantum
- Jul 19, 2010
I've received a BSOD (Green SOD really) "Stop: 0x000000BE An attempt was made to write to read-only memory" error last week and could not boot into normal or any safe modes. No memory dumps were created so could not identify any problem drivers. Last known good configuration didn't work. I used ERUNT to go back to previous registries but that didn't work. I even tried placing an older "good" copy of the windows folder on the corrupted system and got it to load WinXP, but then it crashed with another BSOD "STOP: 0x0000000A IRQL_NOT_LESS_OR_EQUAL". Blue Screen View by NirSoft (via Hiren's boot CD) and WhoCrashed by Resplendence indicated a problem with the file "toside.sys". When I googled "toside.sys" there were several comments that it was related to defective RAM or timings. MemTest86+ v4.10 showed no errors after 13 passes.
If there are no RAM errors, is it possible that my motherboard RAM settings need to be adjusted? What should the optimal settings be?
=== Here is the information provided by MemTest86+ ===
Intel Core i7 2673 Mhz
Memory : 6135M 10048 MB/s
Chipset: Core IMC (ECC : Disabled) / BCLK: 133 MHz / QPI: 4.8 GT/s
Settings: 534 MHz (DDR3-1069) / CAS : 8-8-8-20 / Triple Channel
Memory SPD Info:
Slot 0 : 2048 MB PC3-10600 - Corsair CM3X2G1600C8D *XMP*
Slot 1 : 2048 MB PC3-10600 - Corsair CM3X2G1600C8D *XMP*
Slot 2 : 2048 MB PC3-10600 - Corsair CM3X2G1600C8D *XMP*
Motherboard: ASUS P6T Deluxe V2 with stock settings (except IDE mode for SATA drives)
Video: EVGA 896-P3-1260-AR GeForce GTX 260
SSD: Intel X25-M SSDSA2MH160G2R5 2.5" 160GB SATA II MLC
OS: WinXP SP3
Memory SPD Info:
OS: WinXP SP3
