You mean clear coat it right?altec said:Use a "SOS pad" then clear the metal before you get finger prints on it.
Yes. The SOS won't be the exact same as LiLi cases. You need to get sand paper and experiment with higher grit paper (320+) to get the same look as LiLi.DaRkF0g said:You mean clear coat it right?
or simulated wood grain on metalDaRkF0g said:If you have a high speed grinder and a fine wire brush type wheel you can make swirlies![]()
