Browsing the web using large resolutions.
printer
Hi!
I just bought a Samsung Syncmaster 213T and some sites are aligned to the left when using 1600x1200 resolution. I want all sites to be centered, are there any tricks to apply helping this problem?
Thanks
/Robert
The alignment is due to the layout of the site, and has nothing to do with your display.
Of course it is, hopefully someone has been disturbed by this before me and found a solution. I thought this forum was the right place for such a question.
If no one here knows, the solution probably doesn't exist. :)
It's probably possible but somewhat difficult. You would need something to actively modify the pages as you browse. And each site is different. Some may use css, some may just be plain html. You could probably use Proxomitron to filter and replace stuff. Figuring out what to filter & replace is easy if you have experience making web pages. How to setup Proxomitron correctly is the hard part :p
