It's strange that Chrome is falling, but whatever. It don't concern me if others use it or not, I prefer it (well, SRWare Iron) over the other current options.
WTF am I doing wrong then? I tried the FF Droid browser on my Thunderbolt and it was riddled with bugs. The text box would never work right when posting on forums for example. I thought it was the phone but when I got this Note 2, I tried it again and it still doesn't work right?
Firefox on Android is incredibly slow and crash prone on any Android device I own. My Thunderbolt, Galaxy Nexus, Droid RAZR, Galaxy Tab 10.1 all have issues with mobile Firefox.
The desktop version of Firefox isn't so bad anymore. I'm not a fan on the interface now but that's just me. My wife still uses Firefox though and getting her to use anything else won't happen.
For the record I use Chrome, all Chrome, and nothing but Chrome.
I still believe that their surge in marketshare was the result of it being bundled with almost every piece of software on the net (or seems like it lol). Almost everyone I know has Chrome installed... but they all seem to use IE or Firefox instead
It is and it isn't. Windows 7 actually needed a fairly substantial patch (including DirectX 11.1 components back-ported from Windows 8) in order to run IE10.There is no reason for Vista users to be stuck on IE9 when the core OS is the same as Windows 7 and Windows 8.
That's because Firefox includes a an ancient GDI-based fallback mode (for Windows XP), and is compiled against an old-ish version of the DirectWrite API (for Windows Vista/7/8).In comparison, you can install the latest version of Firefox and Chrome on XP, and of course Vista, just fine.
I use Firefox, but this aggregae of statistics sites listed by Wikipedia says that Chrome is slowly taking over:
http://en.wikipedia.org/wiki/Usage_share_of_web_browsers
So if it's installed but they aren't using it then they arent really counted as a Chrome user now are they? So that wouldn't add up.I still believe that their surge in marketshare was the result of it being bundled with almost every piece of software on the net (or seems like it lol). Almost everyone I know has Chrome installed... but they all seem to use IE or Firefox instead
What a bunch of bullshit!! Why are these numbers so different from these - http://www.w3counter.com/globalstats.php
I still think Chrome is the best when you get right down to the nuts and bolts of it.
If you're going to make use of modern websites utilizing newer HTML5 features, stay away from IE. In fact, don't bother using it until MS decides to play ball.
If you go into about:config and input new integer ui.submenuDelay and set it to 1 or 0, it will make bookmark menus pop up instantly. I'm not sure how to adjust other UI elements but the browser "looks" faster, like Chrome "looks".Is there a way to turn the delay off?
