brother's computer won't start, I'm guessing PS
SkaarjMaster
Well, he's having problems again. Over the past few weeks/days, his computer has been restarting when he does some serious music editing. Today it wouldn't restart and hangs at recognizing the secondary slave (Maxtor 120GB HD). Here's his specs as I understand them:
WinXP
Asus A7S333 MB
Athlon 2100+ CPU with stock HS/fan
1GB PC2700 RAM (2 sticks of 512MB)
Codegen "450W" PS (model no. 350x1, may only 350W, not sure)
standard GeForce2 video card
Audiophile 2496 sound card
standard ethernet card
Primary Master (WD 120GB HD) <<main/OS HD
Primary Slave (IBM 60GB HD)
Secondary Master (Memorex 40X CD burner)
Secondary Slave (Maxtor 120GB HD) << bunch of music here
He tried taking both slaves off and the main HD isn't even recognized (only CD burner). He tried with only the main HD and it hangs trying to recognize it. He switched his RAM stick positions with same result. With only one stick of RAM (either one), system hangs at "Hit Delete for Setup" screen or whatever that is. It also takes forever to get into the BIOS. Ever since he added a third HD a few months ago, the CD burner burns slower as well.
When he first described this problem to me, I immediately thought power supply or RAM. And, even though he told me his HDs in the past died differently than the present problem, there seems to be an outside chance of the main HD crashing. I told him to consider getting an Antec 400W or 430W PS to replace the POS he has in there. Before he leaves tomorrow to get it, he is calling me at work to see what I came up with.
What do you guys think?
If there is a on board Hard drive controller being used, disable it. the Promise controller used on my board didnt recognize my IDE drive giving similar problems. Thats how I got the comp to boot and recognize the hardware. About the random shut down, it could be PS. Go to Bestbuy and pick up an Antec True430 for $99 try it and see if it works, if it does, return it and order it online to save about 15-20 bucks or keep it if its not worth it. And if it doesnt work you can still return it anyway.
goodluck
try sticking the HDs in the freezer for a couple hours, that may help...
oh yeah, and I definitely recommend a new PS, like an Antec... I don't trust no-name brands...
you know.. i have to agree... this accually works (no shit)
I might tell him to do that before he leaves to get the PS. When he gets back, he can take them out of the freezer and try that before he switches out the PS. Should he wrap each one up in a zip-loc freezer bag or what?
Oh, and no extra controllers are hooked up. One interesting thing that happened about 5-6 months ago is he had that same CD burner, DVD-ROM, the Maxtor and the IBM HDs hooked up and everything was fine. Then, he decided to get that WD HD and we decided to put one of the other ones on a Promise controller in a PCI slot. Well, the computer didn't like that and it never worked. He decided to unplug the DVD-ROM and add the WD HD anyway and do an XP reinstall in it.
.....and this is where we are today. Another reason I'm thinking power supply, because this cheap a$$ one can't take it. I still think it's a 350W though and not a 450W; even a cheap a$$ 450W PS should be able to take that, right?
Anyway, any other ideas?
a new psu cant hurt, try pulling everything but the ram, cpu, vid card, and one HD that has an os on it...
checking jumper settings couldnt hurt either, good luck
A no-name 500watt PSU should be able to handle the same as a 400watt PSU from a brand-name company, shouldn't it (just asking because I am building my first puter and dont know sh!t about PSU's)....
Side note: if he's trying to boot with ONLY the Western Digital on an IDE controller by itself, he'll have to take the M/S/CS jumper out—WD drives don't work right when they're set to Master or CS with no other drive in channel.
Yep, I forgot about the HD jumpers as well. Since I wasn't actually doing it myself, I didn't think about it. There is no way he could have changed jumpers that quick, so I'm sure he didn't do it. He needs to try that first I guess. Why did he have to move to Jersey? I'm calling him now, he's gotta be up by now.
.....well, I just called him and his computer is magically working this morning (all drives). I told him all the suggestions in this thread and suggested he just get the new PS anyway. He's madly backing up all his data on CDs now before he continues with anything else.
One thing I would like to add is that his CD burner not only burns slower than it should, but when he installs stuff or reads from a CD it seems a lot slower. Seems like he's right on the edge of what that POS PS can take and should get a new one anyway.
