Nickbaldwin86
- Nov 8, 2009
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing?
YES!
$500
3) Where do you live?
Scappoose, OREGON
CPU
Memory
Motherboard
DVD-ROM
Corsair hx750
8800GS - tell he can get more money together
Case - ATX mid tower - LanCool
HDD
6) Will you be overclocking?
nope, stock cooler will run it or he will use my old H50, even then he will not OC
Already have a monitor res is like 1024x768 - he hopes to upgrade...haha
he has $200 now
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
Doesn't matter
Yes. He has Windows XP Pro... he wants to buy Windows 7 but well after the whole system is built
Will most likely be watching the FS threads and hoping to find deals on newegg... but I figured this would get him a general idea
Thanks
YES!
$500
Scappoose, OREGON
CPU
Memory
Motherboard
DVD-ROM
Corsair hx750
HDD
he has $200 now
Doesn't matter
Thanks
