InvisiBill
- Jan 2, 2003
I was troubleshooting a coworker's PC today. He just bought a SATA drive to add, and couldn't get it to boot with the new drive. He brought the drive in a few days ago, and I was able to see it in my system with no problems at all. Today he brought the whole PC in for me to look at.
Athlon 64 3500+ (I think - something like that)
MSI K8 Neo4 Platinum 1.0 (S939)
Maxtor IDE drive with existing WinXP install
New WD SATA drive added in
2x IDE optical drives
New Thermaltake 500W (550W?) PSU
eVGA 6800GS
It would POST and start to boot into Windows. At the point where it would change from "DOS mode" to "Windows mode", the system would just stop. Screen was black and Caps Lock wouldn't change the keyboard LEDs. The only option was to power cycle it. It did this on a normal boot, in Safe Mode, and even with a BartPE CD. Since it failed exactly the same way even with a LiveCD, that pretty much eliminated the OS install as the culprit, and we turned to hardware issues.
We eventually swapped in another video card. The only PCIe card we had sitting around was a low-profile OEM part out of an older Dell USFF. Pulled the bracket off the card so it would fit in his case, and the thing booted right up to his login screen (and to BartPE as well). Swapped back to the 6800GS and it returned to the exact same failure halfway through booting. Apparently the new drive was just coincidental timing.
I've never seen it before where the card seems to work perfectly in "DOS mode", but completely freezes the system as soon as Windows starts. At that one point, it just seemed to jump from one end of the spectrum to the other.
Anyone else seen this before?
eVGA 6800GS
