Broken sata conection.
stain.
I've got a seagate sata HDD and managed to break the plastic shroud around the data cable on the actual drive.
I'm a little sucky with soldering things that small (my iron is to big :D) and I was wondering if any of you had either a.) a broken seagate drive you could donate to a good cause or b.) the skills needed to do the job correctly.
I spoke to seagate warranty work, and because the damage on the drive, they cannot warranty it, and they refused to send me a replacement plastic shroud. That stinks.
Thanks for your help, and if you are local to Minneapolis, MN and have good soldering skills (or a smaller iron :D), let me know because I wanna get this drive working again.
