TheDarkTao
- Feb 5, 2005
So I hope this is a really simple problem... heres hoping....
I had a horror story with a previous array so I am VERY cautious to rebuild... So here is how it happend....
So I had a perfectly fine raid 1 array with 2x2tb WD green drives. Recently I had a problem with a s3 resume (sleep issue common with gigabyte boards) and when I restarted it reset the bios.
When that happend I reset my overclock settings etc... but forgot to change raid configuration from normal back to raid. As the raid pros know (and this noobie from screwing it up before) if you start a former raid array once to windows, it brakes it for good...
I had this problem once before and the intel matrix program fixed it no problem. But this time as I try and fix it it states an error because (drive has failed, smart error, system data on drive etc...)
I can access all the data and no errors on the drive. Problem is that it has system data I think (since it was a raid 1 on primary)
So..... PLEASE help, how can I safely rebuild this array!!!!!!!
Help is O SO appreciated... after losing a primary before... I never NEVER EVER! want to go through that again
