Broken DP930?
Retardo
I was on my comp. and all of a sudden it just turns off. So i restart the comp. and it works fine then a few minutes later it turns off again. This time it doesnt even turn on anymore. The light stays on orange (means power save or sumtin like that...shuld be green) Move the mouse and hit keys...still no picture. I hook up another monitor and it works fine so its not the vid. card. Hook up the DP930 to another comp. and it doesnt work...so its probably the DP. Any1 had this happen? Any1 kno how to fix? Havnt even had it for a yr yet...got it from newegg.
Wel you have a 3 year warreny from mitsubishi. I have the same monitor and can only say good things
You might try Mistu's tech support..Help you find the problem. Or, it's really broken. Either way they will help you figure it out.
Might even have an answer for a replacement :D
BillR
