Broken DIMM slot?
Deadgye
My friend is attempting to put together his new rig and all seemed to be going well, except we think the second DIMM slot of his motherboard might be broken. I'm not sure enough myself so I decided to post here for a second opinion.
His MoBo is an Asus Rampage 3 Formula, and the RAM we're using is, iirc, OCZ3G1600LV6GK 3x2gb. (I know it's listed in the supported ram for the motherboard)
When we boot up with all 3 sticks in the bios and windows(7 64bit) both only show 4gb. When we tried 1 stick at a time in the first slot, they all worked and bios/windows showed 2gb. When we tried 2 sticks at a time in slots 1+2 it only showed 2gb, slots 2+3 shows 2gb, and slots 1+3 showed 4gb. We tried putting 1 stick in, in the third slot and it booted up fine with 2gb. Finally, when we put only 1 stick in, in the second slot, we couldn't get the computer to boot up. This was all with bios version 505.
Do you think we've determined that the slot is in fact broken, or is there more testing anyone can suggest we do first?
You tried all 3 sticks in slot 2 right?
If so, I think its time for an RMA.
Only tried 1 in slot 2 so far, but tried all 3 sticks one at a time in slot 1 and they all worked. Gonna try all 3 one at a time in slot 2 as a last hope measure when my friend gets back from work then.
Brand new board. We tried putting each stick in the second slot and each time it wouldn't boot. Here's the part that confuses me though.. I went and installed CPU-Z and put all 3 sticks in.. and CPUZ is saying that we have 6144MB of ram, and Channels # says dual. I checked for bent pins but couldn't seem to find any. Only thing I haven't checked yet is the CPU and the CPU pins.
I have seen an I7 have a bad second channel, on the controller. Very very very rare, but possible. I would agree that it is the board though first
Welp, thanks for all the advice so far. We're getting ready to RMA it; I'll probably post if the new one works or not. (It better...)
