sup fellas. So recently i was having some problems with my computer, so i decided i was going to format the HDD. My computer has a 500 gig sata (3 gigs a second) drive in it. All i have is my boot disk, with fdisk on it from like 1998. I tried finding some utilities that could handle a 500 gig drive(before i did my format)..couldn't really find anything. I did however make a boot cd using an .iso from killdisk.com it does a high level write over the whole drive with 1's. So i did that program, kill disk.
The next morning i popped in my windows XP pro cd(service pack 1 included on the disk) and it could not see my hard drive. I tried it a few more times, it gets to the screen where you push F8 to install the OS, then it says "cant find a hard drive, click F3 to restart.
I thought maybe windows(because it did not have SP2 slip streamed on the CD) could not see large volumes like that, so i tried the same thing using a media center edition 2005 version. Same result.
SO what i am asking for from you guys is a utility that i can download, put on a floppy or burn to a CD, that can boot my system, CREATE A PARTITION USING THE WHOLE drive 465 gigs, then format it...so then when i pop in my xp pro/media center CD it will see the HD....help!
