ClariorHincHonos
- Jun 25, 2007
After experiencing some really odd temps with my two 3600 Brisbane procs I went searching for some answers. While it's not confirmed I'd say the conclusion this guy has come to is pretty damn accurate.
http://forums.amd.com/forum/messageview.cfm?catid=22&threadid=85837&enterthread=y
Now my temps aren't off that much anymore after Abit released an updated BIOS-but another user pointed out to me the other day that 53*C(load) on a 65nm 3600 OC'd to 2.47 is a little high, especially when using a Freezer 64 Pro. I starting thinking about that and checked the mating and even went as far as to clean and reapply my AS5. Still high. I'm thinking there's been a "rough" calculation developed for the temperature readings, and that's what is being used. Or maybe I'm crazy? Opinions?
Thank you to all who have made suggestions. All the the programs I have tried can be lumped into two categories:
1) Those that read the voltage drop across the internal silicon diode apply equations to that voltage that do not work for the Brisbane socket AM2 CPU. All of them show temperatures below the ambient temperature inside the case. Right now, for example, ASUS PC Probe II shows 22C.
2) Those that read the internal digital register (Digital Temperature Sensor) read 3C to 6C, obviously not correct with a mother board temperature of about 37C.
The bottom line is that temperature sensing in the AMD Athlon X2 Brisbane (socket AM2) series of chips is broken. AMD's own technical staff are not permitted to confirm that, but they also won't deny it. They have directed me to the same programs suggested here, none of which display reasonable answers.
I'm still waiting for news from AMD, or from anyone here who has a solution for that specific CPU family.
