Yesterday I took the plunge and ditched my CM Stacker 830 for a Silverstone TJ07. After carefully examing the two last night, it's evident that the TJ07 is designed much more efficiently than the 830. I did not realize how much space is wasted in the 830 until I compared them side by side. The 830 is a great air case and breathes well, but it's pretty much useless for watercooling, especially if you have an SLI setup.
Now that I've got an extra 3-4 inches in height and length I have a few more options at my disposal. Surprisingly, I can fit the GTX 480 rad with 4 fans fastened to it in the bottom of the case. So yesterday I mounted my 480 and got to thinking about using it for the 8800 GTX SLI loop and a PA120.3 for the CPU loop.
Before I start drilling holes in this badboy I was wondering if anyone has experience with cooling an E6700 and a set of very hot GPUs on two separate loops and whether or not it's worth it in temperature gains? Right now I'm getting load temps of about 40-41 for the CPU/MB and 55/50 for the GPUs. Using a single 480 rad would pretty much allow me to go internal, but I'm tossing up mounting the PA120.3 on top and running the tubes down through the top for a CPU loop if I can drop the temps even more. The main reason for doing this would be to keep the fans running at a low RPM to lower the noise and to keep the components as cool as possible.
On another note I was tinkering around with the two rads last weekend. I found the 480 rad to go a good job of cooling all components on a single loop. The PA120.3 however struggled with the same loop posting load temps an average of 5-7 degrees higher across the board. I tested both rads fans on full in the same ambient temps, all other conditions constant. Granted that the 480 has an extra 120 on it, it's still the bet choice if it's passive cooling and quiet you want on a monster rig.
