D
Deleted member 79192
Guest
I was wondering if it was possible to bridge a bridged network. Put simply, and in more mental vision-friendly terms, if you used the Windows XP bridge function to link two LAN segments (two seperate local area networks), could you also bridge a third network onto this new, larger network, by having one computer on either network bridge to the third network? Reading over this, it seems pretty complicated, so here is a diagram:
Basically, I was wondering if the creation of a network where all computer nodes could communicate with eachother at the data and application layers would be possible using this method to cover a very wide area with LAN cabling.
Thanks in advance for any info.
- Matt
- Matt
