Scenario:
Two Cable modems.
Two Linksys WRT54G Routers.
One PC running Windows 2000.
One 3Com Etherlink XL 10/100 PCI TX NIC (3C905B-TX).
One NETGEAR WG111v2 54Mbps Wireless USB 2.0 Adapter.
Yes, there are other machines on the network (hence the routers) but they're not important in this scenario.
The 2k rig is wired to one router. It has wireless connectivity to another. Each modem can upload at 256KBs. I'd like to use both at the same time to upload at 512KBs. Is this possible and if so, how would I go about it?
Thanks,
--Fox
Two Cable modems.
Thanks,
--Fox
