Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Was wondering if simply placing a cap in parralel with an LED would cause it to 'breath' the power LED on the stacker flashes in Suspend to ram mode, just wondering if i could make it slightly less annoying.
No, unfortunately, it won't work. A capacitor in parallel will make the LED stay bright for a little bit after it loses power, then go dim and then dark. The speed it does this depends on the size of the capacitor and the current/voltage characteristics of the LED.
The first solution that comes to mind is a 555 timer circuit (to get the rising and falling voltage) hooked to an opamp (to provide enough current to power the LED). I'd draw a schematic, but I have no way to upload it from here (work).
Yeah, i can do that, might have an experiment with a cap in series to see what it does, cant really be bothered for something so simple. only asked cos i couldnt think if it needed parralell or series
The cap will be pulsecharged(if to large) or blink too fast to notice the malformed wave of the output.
You could rig a simple circuit if you had experience with electronics. But if you never took a class or had some extensive experience it would be to try to explain it.
You'll want either a 2-way LED or a second LED.
You'll need a disconnect capacitor.
Then, it gets fed by the SLP pin on the board. Or you can use a direct takeoff of the PSU's +5VSB pin, which should be hot in sleep/standby.
It's possible to make a LED "breathe" using two 555 timers or a 556 dual timer. Basically you use one timer to generate a slow triangle ramp, and the other using that triangle amp to create a pwm-like signal for driving a LED. I can't remember what the circuit looks like offhand.
You could also use a PIC12F508 micro to do it. Requires a lot less parts, but you'll need to know how to program one...
