Hey good folks of [H]
Its about time I hunker down seriously and think about upgrading my current workhorse/gaming station and as such I turn to the only forum one can truly trust. So let's get a crackin'.
I'm a concept artist and designer by trade but am a 3D generalist, and motion graphics artist as well. Programs I use are 3ds max, Zbrush, Cinema 4D, Photoshop, Illustrator, After effects, Nuke and Realflow and a spatter of other programs. I'm an exclusive PC gamer and only accept the best in visual fidelity.
My budget is currently 2k USD but as I usually don't upgrade often this may increase as necessary. I'd like tax to be included if possible shipping may remain out of the equation.
I live in Lebanon and although we do have a bevy of suppliers Id rather I purchase my items in the states.
Well I'd like to upgrade the main components ie MB, CPU, RAM, and GPU unless advised otherwise. I would like to add extra HDDs.
My Rig is listed in my sig and apart from a switch of PSU and a replace of my WD Velociraptor with an SSD everything will remain the same. I Might replace my screen with and upgraded version or a 4k display with a side monitor given the colour fidelity is appropriate but that is a later upgrade.
6) Will you be overclocking?
Nope
30inch 2560*1600
As soon as Nvidia releases their new line of cards. Or of you think I should hold off please let me know why.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Im not up to par with the current tech on mobos but it must be able to handle atleast 32 GBs of RAM USB 3.0, has surge protection, has a lot of expansion bays if possible.
I'm Aok on that front.
P.S.
My manufacturer preferences are Asus Intel Nvidia and corsair. I also like a clean PC, anything that will reduce the clutter that ensues is most welcome. I'd like to be able to do 3D renders fairly quickly for a quick iterative process.
Thank you for the help.
Nope
30inch 2560*1600
P.S.
