Acoustech H100 showed up at my door today.
The back looks almost exactly like this:
Things I've tried...
1. PC: 3.5mm from sound card (Sub/Center jack) to RCA connector plugged into "Sub In".
Result - No sound from sub.
2. PC: 3.5mm splitter from sound card (Front L/R jack) to front speakers and the other line of the split to the "Sub In".
Result - Sound from speakers, no sound from sub.
3. Receiver+TV: "Sub Out" to "Sub In".
4. Receiver+TV: Speaker wire run from L/R outputs on receiver to "High Level Inputs from receiver" area on back of sub.
When doing all of these, I had the volume on the sub at 50% (so as not to risk anything it in case it did start working). Crossover freq was adjusted all around. Phase was swapped. Receiver type was swapped back and forth (a switch that you can tell it either digital or pro-logic receiver).
When messing with the receiver and the sub in digital mode, the subwoofer option was turned on.
When messing with the receiver and the sub in prologic mode, the speaker types were set to small and large (swapped between them for testing) in the receiver.
While connected to both digital and analog modes, the receiver type switch was moved between the two modes to ensure I wasn't missing anything.
Leaving the power switch on "Auto" and removing all connections except for the power cable results in the power light being green. Off switch results in red. On of course results in green. So why would it stay green in auto mode? Could this be related to my no sound issue?
So... any ideas?
So... any ideas?
