Specs-- Asus A8V deluxe wi-fi
FX-53
ANtec 550
74 Raptor and 120 western digital on Via SATA 1 and 2
DVD-RW
eVGA 6800 GT
and the memory I have is Corsair platinum TwinX 3500 registered/ECC, which I know is not ideal for this setup--however, the board is supposed to be able to handle registered memory!
Here's what happened: Tried to boot for the first time with both DIMMS in--got a long, loud beep that would not stop unless I shut the power off.
Took one DIMM out, tried to boot again, got the "System Failure due to overclock" voice message.
Tried with no memory. Memory check failed, obviously.
Put the DIMM back in, played around with the hard drives (swapped them, tried booting with only the 120. etc.), tried removing the CD cable. Still "System failure due to overclock".
So what's the deal? Obviously I am not overclocking at all. I can't even get into the BIOS. I have my new monitor hooked up to the 6800, but it doesn't show anything, I guess because the board can't get past the POST. What could be the problem?
ALso, another question, I am probably going to take the restocking fee hit on this RAM and get an unbuffered pair...what is a good, stable and fast type to get for the A8V/FX-53 combo?
FX-53
ANtec 550
DVD-RW
eVGA 6800 GT
